91 Phazer II Bog
SJRTX
New Brunswick Canada
Sled Starts A-1, Idles A-1 And Runs Fine Hauls Hard But Once And Awhile At Slower Speeds It Will Bog Down ( Load Up ? ) Just Give It A Couple Cracks On The Throttle And It Take Right Off. Wondering If Anyone Had ANY Suggestion Where To Start Any Help Would Be Great.
It is going to be a different problem if it is lean or rich and from your description it most sounds like you are correct with it running rich. Have the carbs been cleaned? It could be an inlet valve hanging open, or a bad fuel pump daiphragm. Do the low speed jets seem to adjust like they should? What is the number of turns out now on the low speed jets? Adjust them for the best take off and idle and see how many turns out each one is.
