07 venture
dewey
Saskatchewan
hope this is the right spot for this but here it goes to start the year the battery was dead had some voltage but not enough to start so i connnected it to a battery i had it fired up right away i disconnected the cables and ran no problem went to put the hood down and noticed the tach going to the top and then to the bottom like on start up(sled ran fine) then i noticed the warning light and the self diagnosis symbol in the corner as well as the code of 46 which means "power source voltage is incorrect" i then shut off the sled tried starting the sled again and nothing as it was cold here i thought i would take the battery inside for a couple of days to warm up and put my optimate 3 on to complete the charge. i installed the battery and everything worked fine started up right away but still had my self diagnosis problem. was this due to boosting from a battery which was the same voltage? do these self diagnosis warnings have a reset? is there a problem with my regulator and if so how do i test for this problem?or can it be something simple as the sled runs fine(didn't run it for too long) any help will be appreciated thanks
Being it was close to dead it should have been charged for a few days on a very slow 2 amp or less trickle charge,how fast did you charge it?
Better yet them optimate are great chargers,the code may reset after a few key turns,if it's fully charged runs fine and all systems are functioning run it.
