what is wrong?
maxman
ill
I clutched my viper with slp pipes and it will go to 8900 rpm and drop to 8200 and not climb back up. this is what i have 8bu-10weights with 4.5 tip 3.1 center with gwg primary. 49/41 with green secondary wraped at 70degrees. Rest of the sled is stock. Ihave 160maines for jetting, power valves are clean and adjusted to proper specs. any ideas?
finish on the helix is a bit much. try a 48/38 or 48/36 helix, of the same brand. with a helix that has a 38* or 36* finish, try a red spring at the same 70* wrap.
