? for maxdlx
webbe
are you running stock spring and valving on that 46 and in which sled ?your p.m. mailbox is full also. thanx.
It was used when I got it, but it has a heavy ohlins spring on it, don't know the rate. it is the 46 wit hi low comp adj, and rebound. Can't beat it. Maxdlx
would you mind posting the # off the rear spring as this 46 shock is a large body shock and they all have the appearance of being heavy. What position do you have your FRA adjuster and how much do you weigh? Thank you.
Spring
Hey I can't find the number on the spring. Ohlins just tapes them on and it must have come off. If you measure the width of the spring it is between 3/8 and 7/16. I have my fra in the heavy, and weigh 270. I have my skid moved back 2.5 inches, thus making the spring lighter than it is. I will do some more checking. I have a heavier center spring that I am going to try this year, to see if I can go back to the center of the fra. Maxdlx
