Need a clutch set up for 1998 SRX 700
VmaX 600
Minot, ND 58701
Looking for a good clutch set up for riding fields and ditches here in ND. I have looked on the Tech Pages and nothing really caught my eye since most are either for drags or are using Heel Clickers.
1998 SRX 700
Bender cold air intake
V Force Reeds.
if your pounding thru ditches w/deeper snow, you will need a different setup, than one used for just bombing down the fields. one setup doesn't work for all.
I would just get yourself a 51/43 rx1 helix and run 8dn-20s white,white,white primary with 4.5grams in both holes may need to add a gram to the tip. and a green secondary spring seems to be a good all around setup and cheap.
