88 yamaha 570
I'm having trouble with my Yamaha exciter, i bought it off my friend for 100 dollars because he blew it up, i cleaned it all up replaced the piston, got it running nice, then it started backfiring and bogging out allot which it always did but i dealt with it, and now i cant get it to go higher than 4000 rpms, i cleaned the carbs when i got it, took it apart today and cleaned it all and made sure my carbs were in sync put it together put new plugs in it and it ran great for about half an hour and then fouled out and started backfiring, i then had my friends uncle help me clean out the carbs more and adjusted the air screw to 1 and 3/4 turns out because were not sure what it should be, can anyone help with my problem or help me to figure out how to sync my choke cable and know what all my carb adjustments should be at? thanks a ton... i can be either replied on this or emailed at minilogo1@yahoo.com
Thanks,
Justin
Thanks,
Justin
