dubla92
I have an 01 SXR 700 with 5000kms on it and at the end of last season it started to run poorly so I parked it. This season I got it running and cleaned the carbs and all the other preseason stuff but it won't idle properly and the headlights are dim. It is also getting harder to start. I checked the stator and it specs out perfectly with no shorts to ground. I also checked the wiring harness under the motor and found no bare wires or broken wires. When it starts the tach needle just bounces at 0 and doesn't respond if I can make it
rev up.
Any thoughts or suggestions would be great.
rev up.
