87 Enticer 340 question...
jimfsr
Grand Rapids. MI
Working on a 87 340 enticer withan ignition problem. It runs, but the spark is intermittent, checked with an auto type timing light. The engine stumbles in time with the light flickereing on both plug wires. Any experience with a similar problem? I have a theory, just trying to get some other input. Also, if anyone has the specs for the coils (ohms) let me know. Thanks, Jim
check for a rub through under the motor 1st. then re-ground the external coil to the motor and to the frame of the sled. odd are though it is just a dirty ground.
