96YamVmaxXT
How do you guys think a 98 Vmax 600 clutch set-up will work on a 96 600? I did all my research on the site about the weights and rpm specs. From what i can gather it should work pretty good. I'm going to have the secondary set at 3-3 with the stock green spring. I see the 98s have a red spring in the secondary. Give me your input!
Snowbear
for a good 96 600 clutch set up go to the tech section and look at Turks list he has a couple there and one of my friends swears by the set up. really you should have a red spring for your secondary but lots of guys use the green cuz of the backshift characteristics. all depends on how you ride I guess
96YamVmaxXT
Thanks.... The reason I'm asking is because I bought a used clutch for my sled off a 98 Vmax. Just trying to figure out if the setup will work correctly in my sled. Guess I'll have to see what happens this weekend!
