vguarantee
Hello- I have a 02 SX Viper with 1500 miles on it. Coolant light came on, checked coolant in overflow. Overflow tank was full but had oil in it, milky. Flushed cooling system and recheck after 15minute ride. Oil in coolant again. Any ideas???
Is the coolant and oil jug together if so is there anyway they can get intermixed? Cracked jug? Did someone put oil in coolant jug by mistake? Did you run a cleaner thru coolant system when flushing? We used cascade dish washer soap (liquid) when a oil cooler goes out of engine at work but not sure if that is something you should use on a snowmobile. If someone did accidently put oil in the coolant jug and it got into the system its going to take some kind of cleaner and a lot of flushing to get rid of it.
