Viper Treats
What is the best way to cut a windshiled?
I've used a roto-zip before. I taped the line I wanted to follow then went to town.
WNYViper
Cutoff wheel works great, did my SRX w/s and the plastics on my Raptor wheeler, take a lil emery paper and a heat gun to the edges to smooth em out
GibViper
DV8 said:I have tried tin snips = not so good. a small air powered jig saw works great for a rough first cut, then use a angle grinder with a sanding disc to smooth it all out.. comes out like factory. Did it on Viper and SRX.. here is a pic of viper.
DV8 - STOP drinking that MI water. Its stunting your growth!
bravo-guy
I took a grinder to my windshield, looks perfect with the trim over it.
jasonlmrx
i used a knif lol! be carefull knif hurt when u cut your hand. not the best thing i wouldnt encourage you to use a knif haha
I trimmed my buddy's Exciterr w/s down with my 2" cuttoff wheel. I taped of a line and followed the line. I then installed some w/s trim from Dennis kirk to finish off the edge, I did use a file to clean up the edge. looks goood Al
GibViper said:DV8 - STOP drinking that MI water. Its stunting your growth!![]()
Yeah i wanted to lose weight and shrink so I could be faster on the sled!
ryanryan
I use a dremel with a cut-off wheel also. Works good, and with the trim back on, you'll never notice it was cut.
