has anybody had any issues with the stop switch assembely for vipers? My brake light only works if i sqeeze the brake lever really hard. i tryed to adjust but cant seem to find out how. Thanks for any help
sounds like your problem is in the switch, by the leaver, on the handle bars.
unplug the two wires coming from the brake leaver and check continuity with a tester should tell you right away.
Thanks i was trying to find a adjustment on it, and there is none, I will check the continuity today, i looked it up and the switch is only $15.00, but nobody stocks it
