2000 Srx 700 Relays
connor1
NY
problem is if both the white relay and the blue relay is plugged in I have no tach and dim lights on high beam but runs strong . when switched to low beam sled misfires.and run rough switch back to high beam no tach and dim lights but runs strong. unplug blue relay have tach and goog high beam no low beam. put a tester on both relays. blue beep on both plugs white onlybeeped on one side. Is the white relay for the lights and tach and the blue for the hand warmers. Hand warmrs don't work would a rub though to the hand warmers cause this and the white relay be the problem with the low beam.
