anyone got a manual for a 2002 srx ..i try to figure why the dcs light doesnt flash 3 time on start up ...all wiring are good ..if i ground the sky/blue wired at cdi the light go on .try to figure if something else could make the light not to flash on start up ....maybe bad cdi this is what i try to find ...
kirk700 srx
email address?
kirk700 srx
Mail sent Mod!
thnx doesnt talk mutch what to check if the light doesnt came on went u start sled .. i know the wiring for the light from the cdi is ok .. still try to figure what would make the light not to come on .....
kirk700 srx
maybe bulb is blown!
no cause if i ground the wire that cdi ground for a test the bulb goes on ........ grrr i always have problem that other people doesnt have lolll
kirk700 srx
Ok... check load control relay for continuity, if good, check knock sensor, if good, check main switch, if good, check voltage on condenser coupler, if good, check stator coil and connection, if good, check pickup coil, if good, replace CDI!!!
well the load control relay must work cause light and all other things work..not sure about knock sensor i will check resistance tomorow.main switch must work all other things work ..i will need to check the voltage on condenser coupler (any idea on to check it and where is that condenser coupler and what voltage should i have ...stator and pick up coil have been change so i know its not the problem ...
what is the voltage i should read at those condenser ?? i think they have 2 of them
kirk700 srx
Your knock sensor should be 504-616 K ohmn @20 C The condencer I am not too sure on
i'm pretty sure it will finish with a cdi failure
kirk700 srx
You could be right...Stranger things have happened LOL
