lakeofthewoodsrider
I have a dead speedo on my 98 srx. I tested speedo...works.
checked cable.....working
new '''key" yup
still no working speedo
Is there anything in the end of the jack shaft? Do I have to pull the shaft to fix?
new '''key" yup
Is the bushing in the end of the shaft still there? It's a little piece of aluminum that presses into the end of the shaft. Stick the key into the shaft and try to turn the key. If you can turn it, the bushing is broken inside. Also, check the speedometer housing. Put the key into where it goes and spin it while looking where the speedometer cable screws to and make sure it spins. It's also a good time to really inspect the driveshaft bearing. The bushing can be replaced without removing the driveshaft but its a pain. I ended up removing the driveshaft and finding a drill bit that was just a little bit smaller than the bushing. I then used some engine oil to keep the bit lubed and drilled very slowly into the bushing. And I mean SLOW. I got about 1/2" into the bushing and it broke free and came out. I tapped in a new one and was good to go.
lakeofthewoodsrider
I tried the housing...that still spins, did not know about the bushing, will look at that and see. is it hard to get bushing out?
