phazer skid swap
djrascoe
Tampico, IL
How much trouble would it be, if any to put the skid off a phazer 2 on my 88 phazer deluxe? Basically i looking to swap them so i can run the 121" track, my 88 takes a 116" and there is nothing available that has much of a lug on it. would this be an exact swap as far as bolting right in, or am I looking at a bunch of modifying?
This summer i put an exciter 121 in my 116 phazer . I was able to use the original front holes but had to make new rear mounts .You also have to mount middle idler shaft in tunnel . You also have to bend or remove mudflap steel mount and extend it for mudflap to be 2 1/2" further back .
