yamyrider Active member Joined Nov 6, 2003 Messages 1,589 Age 58 Location Northern Ontario Jan 10, 2010 #1 the light will go dim then bright. Already did the harness under motor and replaced stator. kirk700 srx Member Joined Feb 14, 2009 Messages 743 Age 47 Location labrador city n.l Jan 10, 2010 #2 is it when you press the brake? yamyrider Active member Joined Nov 6, 2003 Messages 1,589 Age 58 Location Northern Ontario Jan 10, 2010 #3 no it will happen any time while riding ejcamaro Life Member Joined Sep 24, 2004 Messages 907 Age 49 Location Wonewoc, Wisconsin Website www.myspace.com Jan 10, 2010 #4 That's strange, have you tried wiggling on some of the plugs in your headlight harness while it's running? Maybe a bad connection or a ground that needs to be cleaned up? You must log in or register to reply here. Share: Facebook X Bluesky LinkedIn Reddit Pinterest Tumblr WhatsApp Email Share Link
