charles
Reassembling clutch is there a special lubricant that shoud be using or light oil or is a small amount of grease fine.
nothing..is best
NY AttakGT
Clutch Lube
I use dry graphite lube. It is a graphite based powder lubricant. Made by a company called Victor. Comet(the clutch mfgr) also makes some type of lubricant in an aerosol can, but I dont know much about it. -Steve (O.C.)
yamahauler78
Mr. sled is right. My performance shop told me the same when I asked. You clean them up blow em off with air and reassemble.
