clutch change
rtjim
Moreau Ny
Hey guys,
I am planning on installing a srx700 primary on my sxr700, do you guys see any issues with that?
the clutches are the same but the weights and srpings are different. Do you know how the clutch is set up. Is your SXR stock? The read head motor does like a thin heel
weights
My rollers and ramps are shot! If I just change the spring will it still work ok? and yes it is stock
