Powder advise
fishingprospector
Minnesota
I just replaced the clutch side piston on my 2002 viper which only had 1000 miles on it. I am suspecting a carb iced up or I sucked in too much powder. I thought I read something you can shut off when riding in powder. I don't have a manual so I am learning about this sled as I go. Any advise?
Your probably thinking of the carb heaters(little black knob on clutch side of head), most people say to leave them off unless your are riding in powder and/or it is very cold out.....I leave mine on instead of messing with it, I don't think it makes much of a difference.
Carb heater was off (didn't know it was there. I think I will leave it on. I can't stay out of the powder. Hopefully my rebuild holds up. Only ran two miles since replacement yesterday.
Thanks for the advise.
If your going to run a lot of powder, you might consider a pre-filter cover for your air box. It will help keep snow dust from being ingested.
i leave my carb heaters on at all times and never had a problem. i also run a little iso-heat in my tank cus you never know what kinda gas your gonna get out in bfe.
