marinetech
does anyone have any pics of their w arm with gussets added ? I have to repair my old one for my old srx. only want to repair it once and I assume people have tried different gussets in different places. this one broke left side top. any help would be great , thanks , Dana
Have you tryed a search? i think theres pics aroung here..
marinetech
yes I did but no pics
Try the FAQ area.
rx1jim
I am just putting the rear suspension for my 2000 SRX back together, it is on the workbench. I reinforced the W arm yesterday and repainted it. I'll post a few pictures later tonight.
marinetech
okay , thanks
there was.....marinetech said:yes I did but no pics
rx1jim
Here a 3 pictures of how I just repaired and reinforced mine. They my not display too well I should have taken the pics before I painted it black. I added two gusset plates on the top to tie the middle and outer tubes together. I grit blasted the W arm which revealed 2 small cracks, I inspected all the welds. I TIG welded all the joints which are known to have problems wiith a high strength filler rod. I added 3/16" thick x 1" wide bars from top to bottom on the bottom of all 4 tubes.
unchained
Thats some fine fab work and tig welding. Nice job!!rx1jim said:Here a 3 pictures of how I just repaired and reinforced mine. They my not display too well I should have taken the pics before I painted it black. I added two gusset plates on the top to tie the middle and outer tubes together. I grit blasted the W arm which revealed 2 small cracks, I inspected all the welds. I TIG welded all the joints which are known to have problems wiith a high strength filler rod. I added 3/16" thick x 1" wide bars from top to bottom on the bottom of all 4 tubes.
akrievins
wow, what a clean looking skid!
SWEDE
U the Man!!!! ^^^^^^^
YAMAHIZAL700
x2 fantastic work. WIsh you were here to weld for meunchained said:Thats some fine fab work and tig welding. Nice job!!
.Pics might have been posted by Welterracer as they do the repair and powdercoat them
Nice work Jim. I did the same with mine.
sleddineinar
Nice job!!
shaggyzr2
Are all W arms the same for all the pro action sleds? They look the same to me but when I go to a yamaha site it shows different part numbers and some are more expensive than others.
Hammer Down
Some are reinforced
low slung
Welded mine twice on my 04warrior.When it broke the second time they were hairline cracks on the lower joints(on the skid).Just keep adding metal.
Just remove the rubbers and watch how high u put the gussets they will hit the rails.
