bluehammer
I'm looking for someone on TY that perhaps has a list of Bender helix codes converted to which angles they are. We have a bunch in inventory and are not really sure what the angles really are. Any help out there?
NY_SXR700
They are kind of "secret" but if you post what you have many people will respond. If your looking for a cheat sheet, I think Bender would get a little pissed at our Webmaster for posting it. To you and I they are just angles and we can pick the right one just as good (probably better) than Bender. But, the average joe uses bender for their knowledge and TY would be in hot water for posting (IP) Intellectual Property. It's the kind of info that is no good to anyone but the guy who needs it. Like I said we all have cheat sheets and if you post someone will respond. I have about 10 of their angles (mostly older ones). Doug
bluehammer
Bender helixes
Well, I understand the need to be secret, but when one has as specific helix and has the need to "tweak" that helix to get the desired performance, one must first know what one has before knowing what the next purchase should be. But, specifically, I would like angles for the folllowing part numbers: 9870P, 9870,9970,9970c, and 2070. Perhaps you have them in inventory. And thanks .
NY_SXR700
On my sheet this is the only one that I have that matches yours.
9870 53/43
Doug
9870 53/43
Doug
bluehammer
Well, thanks, that's a good start.
sneakysnake
How about VIP02?
i have a 9770tp pretty sure it stands for 97 700 triple pipes, least thats what i ordered it for any ideas
98srx6
sneakysnake
Any one know this one from maxx perf.,6MS7,it was in a 600SX clutch kit 1997.
Are all variable helix's from different companies all cut the same?
Dalton = max perf. = Bender ???
98srx6
watersuper said:Are all variable helix's from different companies all cut the same?
No they are not cut the same.
**sj**
Life Member
NY_SXR700 said:On my sheet this is the only one that I have that matches yours.
9870 53/43
Doug
what about a 9760?????
