abnormal vibration?
Ride.Race.Live
Canada Ontario
Im starting to think I got abit of a abnormal vibration in the engine... only when i lift the hood.. it seems like the engine is shacking abit more then it should... could just be me though... its shacking alot on the beltside like im missing a mount or something but didnt see anything missin and no abnormal noise is coming from it... its runnning great... just seems like the eninge is moving in there more then it should... any clues or is it just me?
any one got a clip to show just the engine running so i could compare?
Ill try n get a clip up of mine... when i get a chance
I once had a loose front motor mount on the clutch side. that could do it. Also, does it stabilize if you rev the engine higher? mine vibrates more at idle than when running higher.
yea at higher rpms it gets better... seems to not shake as much
ill def double check the mounts and stuff make sure everything is solid
