02 srx bogging bad just happen out of the blue the plug are wet it have a hard time to get going it will smoke you right out when you do go no faster then 80km half gas at wideopen it will bogg real bad and will not go. before the bogging my dcs light is come on to at wideopen when went is is running good I let off the gas it will shut down to a idol but if I put full choke on for 2sec it will get move agein if not got to wait for 1 or 2 min
no1chevyboy
?check carbs, oil pump setting, fuel pump
sgauthier
check for a bad spark plug cap(s) as well.
