srx flashing codes
SniperX
Ottawa Ontario
hey guys i have a 99 srx 700 that started to run codes on the temperature light , it started with just a few flashes on and off as if it was warning me that i was starting to over heat (after only running for 10 minutes)
then it stopped , then it started again and was not realy flashing in a consistant pattern but flashing all the time , but the main code that did flash was the water temperature sensor code ,1 long 3 short , any ideas
thanks
