Cdi Box
kedarganesh30
massachusett
Hey guys,
Does any know how to test or to make sure that the cdi is working properly? i have a 99 srx 700 and the servo motor does not actuate i was told that it was common on the 98-99 srx 700 that half the box will not work right so it will not send a signal to the servo. The servo works i hooked a battery direct and tested it, it does actuate but not when hooked up with the wire harness.
Does any1 has a wireing diagram or wireng manual for the 99 srx 700 tripple tripple? Is there any fuses on the 99 srx ?
thanks
i think the servo mot -runs off the lighting coil ? if your buddys got srx 700 borrow theres 2 check it.cdi's cant be check w\ OMS meter.
