Screw-in lug studs -- Do they work?
Mills
Elk Mound, Wisconsin
I put a Camoplast Predator 1.25" track in my SX 600 because my old track was shot. I wanted to reduce the rotating mass and gain better track traction were the two main reasons for picking the Predator 1.25" track. However, I no longer have studs so those icy corners are a little more trickly than I like when riding hard. I would like to try the screw-in studs that are screwed directly into the lugs. Has anyone tried them and do you have an opinion on them? Is there a brand or type that works better than the other?
Any input you can give would be greatly appreciated.
Chad
