hd_yamaha
- Nov 29, 2004
Without adding tunnel or heat-exchangers protectors what is the safest length I can go with on my wife 99 VMAX 500 ..I believe the track .75.
Is a 1" acceptable and safe?
Jim
Jim
1" would work great!!
Tod
shouldn't he put in the tunnel and exchanger protection.
Thanks Tod...I blew right over that part...LOL
hd_Yamaha, there is really no safe length with no tunnel and heat exchanger protectors... nice catch Tod
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
1" is the largest you will want to go or the studs will get to much power per stud and tear out or fold over.
hd_yamaha
- Nov 29, 2004
Thanks for the input.
I went with 96 .875 studs
This is my wife sled and she does not ride hard at all..it more for traction going up a hill or icy turns.
I did not want to take the track out to do this ..
So I guess I will go with the protectors...
can you get the heat exchanger in without removing the track?
watersuper
Are you asking about the heat exchanger or the protectors for them?
you will have to drop the skid to get the tunnel protectors in and remove the seat and I usually loosen the tank.
hd_yamaha
- Nov 29, 2004
What about the heat exhanger protector...do you need them?
I looked on the yamaha web site and it looks like that you can install them with out removing the enter track. Is this true?
yamaholic22
yea you should definately run the heat exchanger protectors. Better off going through the trouble of putting them on compared to having the studs go through it on a big bump, leaving you waiting for a tow out of the woods, never fun.
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
Whenever you are able to run the protectors, you should definitally do it. However, when people buy tracks bigger then there sled can take, they take them off. If you are running studs, you always want to be running protectors no matter what. never run with out protectors when useing studs.
