BENDER RED & YELLOW SECONDARY SPRING
SHARKATTAK
MASS.
Bender Red & Yellow Secondary Spring
does anyone know the force of the bender red & yellow secondary spring and and the yellow & orange primary spring, what is the bender 02vtp helix angle? also, i have 8ek-00 weight totalling 52 grams, what are the stock weight of the 8ek-00?
8ek-00 = 39.0 grams empty. i got the same red/yellow secondary spring but don't know the numbers on it, got very high side preasure and less twist force than the usual red or green yami springs.
i was just wondering i got the whole kit in the ty classified, the 8ek-00's the springs and the helix, thanks
i looked up the stock weights with rivets is 70.1 grams, and these are 52 grams even, so the bender kit must come with rivets to change
the stock weights with stock rivits weigh 47.1 g the numbers you used are the length of the rivits 17.2mm=4.5g 13.9mm= 3.6g.
my bad, but the one i got here are 52 grams so they must have come with rivets, anyways i got it all in the ty classified if someone wants a clutch kit
BENDER YELLOW-ORANGE
PRE-LOAD- 50
TOTAL- FORCE - 107
I HAVE TO DIG FOR OTHER STUFF INFO. I MIGHT BE WRONG, GUY I KNOW BOUGHT A CLUTCH KIT FROM BENDER FOR A VIPER AND I THINK THAT WAS SPRING IN KIT.
3:16 (yammie tony)
my guess is that the "02VTP" stands for '02 viper triple pipes. my guess on helix is probably like 51/45 or 51/43 maybe. just guessing....never had one in my hand.
PRE-LOAD- 50
TOTAL- FORCE - 107
3:16 (yammie tony)
let me know if you find out any other info on it, thanks
YAMMIEGOD, what i trying to do it compare the bender springs to Yamaha springs, can you break that down for me?
PRE-LOAD- 50
TOTAL- FORCE - 107
3:16 (yammie tony)
1.72kg rate??
YAMMIEGOD3:16 said:
MY INFO IS SHOWING THAT IS A YAMAHA SPRING. IS THIS SOMETHING DEFFERENT. 3:16 (yammie tony)
they are yamaha springs? i couldn't find them in the tech section, they both came from bender
SHARK, THAT SECONDARY SPRING IS A BENDER CUSTOM BECAUSE NO WHERE DO THEY POST A SPEC ON IT, YET OTHERS THEY DO. THAT YELLOW/ORANGE IS A PRE-98 YXR CLUTCH SPRING. SLEDS LIKE VMAX 4 750, VMAX 600, 500. IT HAS A HIGHER PRELOAD THAN ANY OF THE YXR SPRINGS AND A TOTAL FORCE BELOW THE W-W-W. WAS THIS SPRING USED ON A VIPER ? 3:16 (yammie tony)
Thanks YAMMIEGOD
