"Slight" electrical problem, SRX
NorthernPower
Norway
"Slight" electrical problem SRX, help!
Hey guys. so today i finally got the srx together and started it, runs perfectly. (98' srx600)
I have built it up from banana-boxes of parts so im stoked it ran so well :)
anyways as it was idle'ing for about 10 minutes the lights started to turn on and off and i noticed also that gauges, taillight, oil light, everything was out, so no current at all to the sled, except the coils i guess, since it was running.
I believe that the grip warmers were still functioning aswell..
Took it for a spin and the electricity came back for a few secs, and then dark again..
Any suggestions as to where i should look? I'm thinking bad connection somewhere, that maybe "rattled" out of place as it was running..?
could it be the main from stator?
sorry for long post.. thanks =)
-Ray
TJ500 said:
check Load Control Relay by your left knee, near the large clip for your belt guard... this relay controls ALL you have mentioned... tj
cool, thanks! I'll check it out first thing after work :)
damn.. now all electronics on the sled is off, it was good for a while but then lights started flashing on and off and now completely gone.. sled still runs tho..
i don't know how the Load Control Relay looks, and it doesnt really make sense with the drawing in the service manual.. any thoughts?
oh and it blew the front low beam light, only worked for a short while on high beam after that..
i have this same problem on my sled, i think it started when i hit a buried pile of rocks and rolled my sled(oops) but then i noticed when i turned the low beams on the lights went out, but when i moved the bars a bit they came back on, so i ignored it until it started doing it with high beams as well, i wound up pulling all the top plastics off to tune my carbs, and un-clipped all electrical, clipped it all back together and made sure there wasn't any loose wires and presto, no electrical cut-out. id say long story short, im almost positive its a bad connection, un-clip everything wiggle the wires to make sure they aren't loose, and put it back together and see what it does
ok, I will check all of the above..
i also noticed wigling the handlebars made the sled light up again for a short time, could definately be a bad connection.
thanks alot guys :)
sounds like rub thru .....pull wire harness from under the motor ...most likely the blue wire is rubbed thru grounding itself out on the belly of bulkhead ....tape each wire single and than tape all them together and reroute across top of carbs ....
good, i will check this aswell, thanks :)
daman said:
Post #6 ,you would have found the procedure to do it as well by now.
yes, haven't got around to yet:) and also didnt know where to rereoute the harness to, so good clarification..
I'll get on it sometime this week :)
