coorsloader315
I have a 2001 sxr 600 and was wondering if im wasting my money by running premium fuel in it( 93 octane) ?
coorsloader315 said:I have a 2001 sxr 600 and was wondering if im wasting my money by running premium fuel in it( 93 octane) ?
sideshowBob said:Stock SXs + SXRs["red heads"] only call for regular fuel...I would run mid grade 89[just to make sure you are getting at least 87!!!]
Higher Octane then you need is a waste of money + actually hurts your performance.
JM.02c
Actually all 2stroke yammies excluding the SRX require 88 octane OR higher via your owners manual.backwoods said:your sx600r is recommended to just run 87.
maxwell said:You could use the argument of ethanol in the lower grades of fuel, and usually not in 91 ocatane
snomofo said:Actually (in Michigan anyway), you're more likely to find ethonal in mid and high octane fuel than in low octane fuel.
Yamadooed said:If you blend ethanol to regular fuel you get high octane premium... They been do'n it here for years...
maxwell said:Interesting,
In MN and WI, they usually do not have ethanol in the 91 octane fuel.
