00-02 700 srx heads on 98 cylinders?
madpat
Laona, Wisconsin
I have a 98 SRX 700bottom end(welded crank),98 cylinders,V-Force reeds,reed spacersCan i run 2000-to 2002 (8dn-10 ) heads on it.Is there a advantage to it(more compression).Do i have to run the 2000 -2002 cylinders as well?I have 98 heads that been cut but i wrecked 1.
'00-'02 heads will bolt on and make more power, but be sure to check trapped comp ratio, as exhaust port is lower on '98-'99 cylinders, so comp might get too high for 93 octane.
