lilsnopro
What's the difference between the 1976 and 1978-1980 srx pipes. I can't tell which set I have. They look like my 1978 srx pipes but I can pull out the ends? Thanks.
pipes
Sounds like 76 pipes with the removable ends. 78-80 are fixed.
jwurl
The 76 pipes look nearly identical to 78-80 pipes. The easy way to tell is the end of the pipes near the muffler have bolts on them. Jeff Wurl
YAMMIEGOD3:16
I DISAGREE. THE 78-79-80 PIPES WERE AND ARE THE SAME. THEY RUN AT 8800-9000 RPM. THE 76 SRX RUN AT 9500, YOU LAY BOTH THESE EXHAUST DOWN ON THE FLOOR YOU CAN SEE THE DEFFERNCE IN SIZE OF THE EXPANSION CHAMBER AND THE LENTGH OF THE PIPE AT THE BACK GOING INTO THE MUFFLER. I,LL TELL YA THEY ARE DEFFERENT BECAUSE I GOT CAUGHT USEING THEM AT THE NEW YORK STATE GRASS DRAG CHAMPIONSHIP AT MARILLA ON A 78 SRX. 3:16 (yammie tony)
