Anti rachet drivers - Where to locate
tagoes10s
Niles, Michigan
I'm putting 8 tooth anti-rachet drivers on my 02 viper. Does anyone have the specs on exactly where to locate the drivers on the shaft?
Dan
02 viper
I have the std driver locations but those should be located center of the track windows. Try the RX/RS forum, quite a few guys on there have them on their RX1s
drivers
from non splined end 4.5 inch to center of driver and center of driver to center of driver 8-7/8" thats for rx-1 and I dont know if that will work forothers
lippy :4STroke:
I have a few different specs for driver placement, but I need to know which drivers you are running, as distance will change by brand/type. Also I did a set of extros for my dad and he had a oddball track, which I had to re press the drivers for...
