Haddly
- Nov 10, 2003
I want to add a 4th boggy wheel to the rear of my 98 srx and was wondering if anyone knows where to get on and what the web site is. Thanks
AtlasFBG2
http://www.richmotorsports.com should be able to get them if he doesnt have any on hand.Hes a great guy to deal with.
snowjoe
- Sep 23, 2003
i would not put the 4th wheel on that srx ive seen alot of rails crack. i would go with a size larger on the 2 front wheels i think the viper has a larger front or a newer polaris wheel will work. did this to my 99 srx and the sled rolls like a dream on only had to replace hyfax once in 2 years 4500 miles.
TopGunnSrx
i would put it on but you must must make sure you get the right spacer for in there or else it will be off line my 01 srx i have some bender blue tubo wheels under it all 4 in the back never had a problem 4 wheels is better then 3 you have now i would do it rich should be able to hook you up with whatever you need
black john
- Jul 5, 2003
fourth wheel
its all in the tech section on this form and its veay easy to make your own plus your track should last longer (less flexing were the wheel is not now) i found this to be true on lots of even brand x sleds the tracks all seem to brake up in that location once you get lots of miles on them, its all good stuff
I made my own also.all you do is cut down the stock spacer.i have the wheels for $20.let me know if you have any questions.
