kedarganesh30
i have 7 flashes on my temp gauge anyone knows what that means?
Discontinuity or shorting of the servo is detected.
open up servo,lower idle to 900 rpms does servo cycle the vales open?
kedarganesh30
what do you mean by discontinuity? yes the servo actuates
erratic operation...
ok so vales actuate,do have any stuck valves or adjustment issues?
mine was doing that ....power valve cable was too tight ....does it olny do it when hard on the gas at high speed ?
kedarganesh30
i may have adjusting issues the light flashes all the time it takes a few the sec the flashes 7 times agian. the other problem i have is that it runs good from idle but as soon as u let off the gas and try to hit the gas right awy back it bogs down you have to bring it to and idle and then it goes good again.
i also swaped out the power vales with housing complete withe the servo and cables from a 2000 srx the cables are longer would that cause a problem too?
you got a 98 ? you said longer cables 98 had short cables ....servo mounted on the front of the airbox or on the side of air box in front of your left knee if sitting on sled ?? i just pm you with my number call me if you need answers asap
