Primary Clutch Interchange
96YamVmaxXT
Maine
Hey guys, quick question... Will a primary off a 96 vmax fit and function on a 2006 nytro. It would be set up to specs for the nytro. I just want to know if it would work. Thanks!
i don't think that will handel the 4 stroke tork. it's too thin.the 4 strokes has a thicker movable face.i wouldent try it i may be rong?
You won,t be able to use the 4 stroke weights but it will fit. The 4 stroke primary clutches have a slot cut in the spyder arms for the thicker weights to clear at full shift.
