EGGMAN
I have a 1998 xtc 700. Last week I noticed some oil spray on the clutch cover and on the belly pan that was in line with the inside edgeof the clutch, between the motor and the clutch. I had accidently spilled some oil the week before while filling it up. I cleaned it up the best I could without removing the air box, but there was still some remains that I couldn't get to. Could that have caused the oil spray? Has anyone else seen this on theirs? Since then I have taken the air box off and cleaned it better. I have not been able to ride for any distance to see of the spray comes back. Thanks
no1chevyboy
between the clutch and motor? possible bad crank seal
EGGMAN
It looks like it is from there, but I tried spraying carb cleaner by it and nothing happened. Also would it blow out oil or would it be a vacuum?
EGGMAN
Any other ideas?
Spray around that seal with starting fluid.
EGGMAN
I tried starting fluid and the seal seems to be fine.
bluebandit98
thats not the crank seal thats a sealed breaing the crank seal is on the other side of that bearing last year i had to replace my bearing because it was leaking oil out of the sealed bearing an i also tryed the starin fluid too find out it wasnt a crank seal at all an i jus bought th enew bearing i paid around 85.00 for it
EGGMAN
How hard is it to replace the crank bearing? Do you do the seal at the same time?
witch bearing?EGGMAN said:How hard is it to replace the crank bearing? Do you do the seal at the same time?
if it's the middle one it' needs to be sent out or taken to a shop to be pressed apart then back together.
yes yes yes always new seals when your in there.
bluebandit98
you jus have the outer bearing pressed off an put a new one on any local reapirshop should have a press
bluebandit98
the outter bearing seal is whats leaking the bearting already has the seal in it
Mad Maxx
- Feb 18, 2005
same thing happened on my vmax 700. turns out it was caused by a hole in the bottom of the bulk head. I'm guessing the extra water down there caused all the oil and crud to make its way to the clutch ,which slung oil as you described. plugged the hole with jb weld and no more oil spray. sounds crazy but problem solved.
EGGMAN
Thanks for all the replies. I am taking it on a trip this weekend and am going to watch it close.
