poonjab
I have the option of putting a Heel Clicker weight set in my MM700 primary and a new bender Helix. My sled has Bender triples on it. Does anybody have input on this setup? The elevation the we ride is 3000 to 7000. What weight setup should I use on the heel,mid and tip? Should I use the grey spring or the red one? I appreciate any input you have.
Use the red hc primary spring. Also use the stock helix. Bender makes about 500 different helix,s so if we don,t know the angle we can,t help. I would start with 4 grams heel; 3 grams inner & tip empty.
poonjab
Thanks for the help. I have the helix in my shop. I will check the angle on it.
