I had the entire fuel/oil system out and apart. I see what appears to be a bleed screw for the oil bolted on the reed flange. I just wanted to know the proper process.
Thank you
Oh yea it's needs to be bled, if this is on your srx fill the oil tank then crack the bleed bolt open,let run till all bubbles are gone.
now there's going to be air in the out put line going to the fuel pump now you can start the sled pull up on the oil pump line to force into full flow to get the oil mixed faster.
or run a little pre mix till engine has run a wile and all air is worked through.
