CLUTCHING: 700SX/R
bleueje17
WNY
I own a 700sx , and have just purchased bender triple pipes. I had this thing dialed in before(unreal), but now I need to redial the clutches. So back to the drawing board.
I have a 700 sx converted long travel. Stock gears (for 99) , carbon reeds, head gasket mod, reed spacers, camo predator 1" with 144 picks.
I now had a can and changed to bender triple pipes.
I ride trails & fire roads with a lake once in a great while. I am more interested in trail, but do not want to die at 90 mph. I have the primary set up with 89L / 2.4 / w sil w, and the secondary is what I am after. I have a 53/41 helix, but I am not sure that will do what I need or I have the stock (99') helx
Please share your experience
THANKS IN ADVANCE
John
WNY
Man...how many times have I done this one? Run the stock w-s-w primary spring, 89L weights, .8 gram rivet, 51/45 helix, green secondary spring at 60 or 70. You may need 70 degree wrap if you hook real hard or need better backshift.
