95 vmax 600 head bolt torque?
captjake
michigan
Last year my 95 vmax 600 head gasket would pop alittle when started up then after that it smelled like it was burning some coolent. So the first thing I want to do this year is replace the gasket. Anyone know what to torque the heat bolts to? Should I used thread locker? Should I torque the head down start it up and warm it up then torque it again?
I did order a service manual, but won't have by the time I need it.
Thank, Any help would be great.
Jake, Michigan
Cylinder head torque is a 2 step method 14 ft lbs then 22ft lbs torque. You could heat cycle it and check it, No threadlocker required.
