96YamVmaxXT
Sleds revving to high... about 8500 rpm (96 vmax 600) Has 8ab weights with 4.5g in tip w/ BPB spring. What should I add to middle hole for weight? Has red spring in secondary at 60*. Also will more weight change how the sled back shifts?
Thanks!
Thanks!
no1chevyboy
is it piped? try 50 in secondary mine does the same thing but was 9000 i added 4.5 to middle and it droped to 8500
96YamVmaxXT
No its not piped yet, I have some on the way but will likely wait till next season to install and tune sled. I just want to ride it this season. I'm going to go to the dealer this weekend and grab some weight rivets from them, sounds like adding 4.5g to middle whole and change secondary to 50* should do it?
no1chevyboy
well according to my info you should have a green spring in secondary if stock wraped at 50%(2-3) and primary has 17.2st in outside 10.3al in inside, sure its stock? new belt?
96YamVmaxXT
Rest of sled is, no mods... clutches are not because of issues with cluthes that were on it so i replaced with used units
no1chevyboy
heres the gyt twin pipe clutch set up primary ppp spring 17.2 in inner 10.3 outer (secondary green wraped at 50% (2-3)same as stock)
96YamVmaxXT
17.2 inner and 10.3 outer? So swap weights from stock and install stiffer spring?
no1chevyboy
yep thats all for the gyt twin piped setup
96YamVmaxXT
Alright sounds good, I have a set of Reichard pipes coming for it, curious to know if the setups will be the same? I plan on going to my local dealer and hopefully getting some rivets tomorrow. I'll probably just get an assortment to have.
