warx22
i have a 2000 sxr600 and i have been searching forever and cant find much on this sled . my set up is stock it eng,s at 3800 and wot is 8200 whats a good trail-lake set up ? and i still want excellent take off but dont want to sacrifice top speed toomuch. going to the city tomorow to buy what ill need any info and how set up performs ????? thanks this site rules.
2003VIPERER
97-98 SX600 Trail
51/43 Helix, 8-ab weights , stock springs and gear up one tooth.
2003VIPERER
99 SX600 Trail
51/43 Helix, 8-ca weights 0.8g in tip, 2-3 engagement shims, stock spring primary, silver secondary, 1 or 2 layers removed from head gasket and 20/40 gearing. Jetting: 140 mains
those are for the 2 cyl models. I have not played with 2 strokes in 5-6 years. Just get rpm,s up to 8500 & call it a day. This is the 1st 600 triple i ever saw that is underevvin. Should not happen unless clutching has ben tweaked.
warx22
should i just add some shimsTurk said:those are for the 2 cyl models. I have not played with 2 strokes in 5-6 years. Just get rpm,s up to 8500 & call it a day. This is the 1st 600 triple i ever saw that is underevvin. Should not happen unless clutching has ben tweaked.
post your clutch set up primary and secondary,all of it we need that info to help.
warx22
totally stock
primary y g y 8dg /10.3 & 13.9 rivets i asume are stock not sure just got sled this year but been driving since 04 was the bosses sled never touched clutches secondary red spring wrapped 80* 47*helixdaman said:post your clutch set up primary and secondary,all of it we need that info to help.
yamyrider
those things normally over-rev when stock..shims the fix
Your sled should overrev like crazy with that set up. Somethings up.
warx22
what should i replace im in to the dealer tomorow whats a rebuild worth
impossible to diagnose the possible issues you may be having on the internet.Clutches been cleaned lately?
warx22
no i dont think its been done since i cant remember . doing that this weekend so i would like to have parts on hand cause i was planning to rebuild them both this summerTurk said:impossible to diagnose the possible issues you may be having on the internet.Clutches been cleaned lately?
yes no kidding should be over rev en to the moon,is this thing running right? firing on all 3 cyls?
