NYsledneck
At startup the light flashes 3 times saying everything is ok But right after that the temp light starts flashing at a steady pace and doesnt stop. I cant see any kind of pattern with it at all. And this started as soon as i fired the sled up after sitting for a couple months. Any ideas whats going on?
so it'll just keep flashing as long as the sleds running huh?
tofastSRX
mine did that last year i thought it was a faulty sensor but when i went to replace it i found a broken wire right at the connector under the head were the sensor in located .good luck
NYsledneck
Ya it blinks steady the whole time its running. I repaired the harnes under the motor last season. Guess i will check the wiring to the sensor.
