drop brackets on a phazer 2?
JordanHall488
maine
i recently put a 1.5 inch track on my phazer. goes great!. but if the bumps get big the track will hit the tunnel. i have heard of people lowering the suspension. does anyone sell these?
track
I'd say the long lugs are hitting the tunnel. I'd just put a set a tunnel protectors on. Pull seat and gas tank and rivet them on.
thanks, ill call tomorrow. how much do they lower them? like 2 inches? does it affect much as far as handling?
if you have the 1-1/2 track with the stock drivers???
have a 92 that I want to install a 136 x1-1/2 and most likely build a tunnel extension
i went with 7 tooth drivers. it clears fine up front as long as you have 7 tooth,but it hits slightly in the rear if you bottom it out. i have yet to find a tunnel extension. you wont believe the traction you will see if you go with the 136x1.5. no one can follow me off trail. the gear reduction with the 7 tooth drivers is quite a bit, makes for plenty of power to turn the longer track.
