Studding Questions
BigToe
Need to puts some studs in a 1989 exciter.
96 down the middle.
Will I need tunnel protectors?
Heat exchanger protectors?
Will .875 studs be too short or too long?
Thanks for the help
Mark
You could get away with not installing protectors if your not riding down bumpy trails or jumping.Which i doubt you will be with a old exciter.But if you do then it would be a good option.875" work fine.I used them in some old sleds i had.
tunnel protectors=$30
rear heat exchanger protectors=$50
96 studs,backers=$124.80
