2000 SXR Oil Cable
KEVIN
VIP Lifetime Member
OTTAWA
Hey
I think my sled is using too much oil.
Should the distance on the oil cable adjustment be 2mm?
Does less than 2mm mean more or less oil going to the engine?
2 mm wow ....guess that the splash of gas is to make the oil burn....sled must be great on gas but hell on oil .....does it leave oil puddles on the ground while u let it idle ?
OhYA
I got the numbers confused between throttle cable end play and oil pump cable.
I will check tonight.
