Need help with clutching
canfieldcoll
Newhampshire
2001, srx700, Bender can, cold air box, tranfer rods. Clutchs are all stock,Looking for 1000 foot set up? sled was turning 9000, playing with helix got it down to 8600, Any one have a good set up for 1000, feet? I know bender and hauck sell clutch kits. But im looking for 1000, feet set up. good for what little is done to the sled. I have been told best way to get rpm down is weights and spring in front clutch.
Get rid of the Bender can and put a stock can back on!! As for the clutching Do a search! there are hundreds of posts about this topic. Go to the tech page and look at the set ups that are on there. Some setups work great for 1000' runs but suck on the trail so it just depends on what you are going to do with the sled.
second on DUMP THE CAN its only good for making noise, and weight loss.
TURKS Setup
New 2002 SRX700 1000ft
51/43 Helix, 8-bu weights w/3.6g rivets in tip and 2.4g in 1st hole, WWW primary spring, Green secondary spring
He has a couple setups in the tech section. Go to TY home. The tech pages, snow teck the clutching and tuning I belive 3 link down. Then click on clutching tunning and jetting page
