Carpenter5.9
Just bought 02 viper, 5400 miles. Just got back from up north (philips wi) ran flawless!Motor hasn't been touched + fogged every year by previous owner.But hear so much about crank failures. What causes it? Should I be worried? Thinking about getting another one,couldn't get the wife off it! Could have worse problems, Thanx!
02ViperMtn
measure you oil to gas ratio next ride. You want to be around 50:1
Carpenter5.9
The gap is 20.44mm?
Ok good..how much oil are you using to gas??Carpenter5.9 said:The gap is 20.44mm?
Carpenter5.9
daman said:Ok good..how much oil are you using to gas??
Don't know? Haven't gone through a full tank yet. How do you check how much oil you use?
SRXmathias
Fill it up with both gas and oil, then drive and fill it up again and measure how much you get in there and calculate :-)
try to get us some accurate numbers with the info lade out by SRXmathias then post back...
we need to know how much your using...
Carpenter5.9
OK,will do. Thanx daman!
no problem...
02ViperMtn
for oil, mark a line in the narrow part of the neck and fill it to there. It gives a better reading.
